help me pick what oil vicosity
Car: 1986 Pontiac Firebird s/e
Engine: 305 Chevy
Axle/Gears: 2.77 for now
Sirs,
I have a 1986 Pontiac firebird s/e w/ a LG4 engine with 130K highway miles. I just put in a used Comp Cams 260H cam, and a Edelbrock 2101 intake. What oil viscosity should I run, after I break this cam in? I'm going to use a synthetic brand.
Engine: 305 Chevy
Re: help me pick what oil vicosity
VI, I wasn't sure which way to go, due to the 130K miles, and the performance stuff that was put on this car. Vanilla Ice, that's pretty funny, at least you're not riding around a 5.0 stang, anymore.
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I don't believe in running thicker oil just because an engine has a lot of miles (if that's what you're thinking).
I have an engine that just turned 440k miles in my daily driver (it's not a SBC) and still use the recommended 15w-40. The engine uses a quart of oil every 4000k miles. I figure it's lasted this long, why change?
Put what the oil cap says in it. (10W-30 most likely) Don't outsmart yourself.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Even though I still change my oil and filter fairly often I use this.
I always do a lot of research on products for my car before buying them. This has 5 stars reviews every where I looked.
= http://www.walmart.com/ip/17128878?w...429488&veh=sem
and this.
Its the "tall" filter # M1-302. Its for Chevy Trucks but fits our cars perfectly.
You always fill the filter before installation.The filter alone holdes almost a quart.
= http://shop.advanceautoparts.com/p/m...-302/3730012-P
and this.
