Ticking Noise Coming From Engine
Old Apr 7, 2016 | 12:00 PM
jbrawner88's Avatar
Now I have been told a few things that this could be and before I go acting on their opinions, I would like others' advice. Please watch the video and tell me your thoughts on what this may be. Anytime I crank the car, whether its hot or cold outside, day or night, it makes this noise. By the time I get home from work, or to work, (about 45 min drive) I can't hear the ticking anymore. The oil is full, I checked it yesterday.
https://youtu.be/Gu54cgWDHZc
Old Apr 7, 2016 | 05:25 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Re: Ticking Noise Coming From Engine
Sounds like an exhaust leak, but depending on what type of oil you're using it could be a lifter knocking. That engine should be running 5w-30 and if you put something ticker in there, like 10w-30 or 10w-40, your lifters will knock until the car warms up.
Old Apr 7, 2016 | 08:57 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Sounds like an exhaust leak. Once your manifolds heat back up and expand again the noise goes away. So manifold gaskets and or dounut gaskets at the y pipe
Old Apr 7, 2016 | 09:13 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
thirdgen.org, #1 place for Buick diagnosis
Old Apr 8, 2016 | 09:27 PM
jbrawner88's Avatar
So what if I have been putting in the specified type of oil, then what could be the issue?
Old Apr 8, 2016 | 09:34 PM
thtanner's Avatar
See above
Old Apr 9, 2016 | 12:34 AM
DonW's Avatar
Car: 1983 Z28
Engine: Carbed 305
Have you checked the blinker fluid?
Piston454
May 31, 2016 12:04 PM
Brandon Royer
Apr 26, 2016 03:40 PM
MrMaterial
Apr 9, 2016 11:42 AM
x_man
Apr 8, 2016 06:00 PM
x_man
Apr 6, 2016 08:38 PM
