hot start issue
Old Apr 6, 2016 | 12:45 PM
Piston454's Avatar
Car: 1990 RS Camaro
Engine: 400 sbc throttle body
Transmission: world class t5 manual
Axle/Gears: 3.73's, Detroit TrueTrac
hot start issue
i am running headers yes. I never had this problem with the 350, i did a 400 swap (also with the same headers). Put a new starter on, heat shield, new positive battery cable and checked my connections to make sure they were clean. Checked ground cable for good connection and it still struggles to start when i drive it for 30 plus minuets. The whole starter engages and turns over, but it does it super slow and wont start sometimes. have to let it sit for 20 minuets or so. any help would be great.
Old Apr 6, 2016 | 12:58 PM
stephenscamaro's Avatar
Car: 1988 Camaro
Engine: 2.8 to 383
Re: hot start issue
Sounds like a tired starter-
Old Apr 6, 2016 | 02:56 PM
Piston454's Avatar
Car: 1990 RS Camaro
Re: hot start issue
But the starter is brand new....
Old Apr 6, 2016 | 02:58 PM
Car: 1988 Camaro
Engine: 2.8 to 383
Re: hot start issue
Could it be the headers are still getting the starter hot with the heat shield?
When it is cold, or first start of the day, does it lag at all? It could be that you need to shim it too~ does the starter make a LOUD almost whining noise/grind during a hot restart?
Old Apr 6, 2016 | 03:21 PM
Piston454's Avatar
Car: 1990 RS Camaro
Re: hot start issue
cant be the headers i dont think, like i said before i had a 350 in there with the same exact headers and it never once gave me this problem, and i didnt even have a heat shield on my 350. it will start no problem when the engine is completely cooled down. and no it doesnt lag and no it doenst need to be shimmed. it doenst grind or make any weird noises (hot or cold starting).
Old Apr 6, 2016 | 03:37 PM
Car: 1988 Camaro
Engine: 2.8 to 383
Re: hot start issue
Have you load tested your battery?
Old May 31, 2016 | 12:04 PM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
Re: hot start issue
I've had issues with my starter for years.
How much space is there between your starter solenoid and the exhaust?
cannibaljeri
Mar 20, 2016 02:26 PM
89Zleeper
Mar 16, 2016 06:55 PM
marz1129
Mar 10, 2016 04:34 PM
stephenscamaro
Mar 10, 2016 05:17 AM
ellefsonz
Mar 8, 2016 08:10 PM
