Coolant Temperature Sensor...
Old Apr 10, 2016 | 03:58 PM
MustangBeater20's Avatar
Car: 1991 Camaro RS
Engine: Built TBI 350
Axle/Gears: 3.42 Posi
My car hasn't been starting cold lately and looked at the coolant temperature sensor. However, I don't think it's the sensor. The wire isn't getting any power on the test light with the key on and when it's running. Anybody have any ideas why the wire isn't getting any power?
Old Apr 10, 2016 | 04:45 PM
Re: Coolant Temperature Sensor...
Because it's not supposed to.
The sensor is a variable resistor. The ECM measures its resistance. It doesn't feed enough "power" to light a test light, just like your DMM doesn't do that when you put it on ohms.
Why do you not "think" it's the sensor? What's the sensor's resistance at a variety of temperatures?
Old Apr 10, 2016 | 05:19 PM
Car: 1991 Camaro RS
Because I replaced the sensor two years ago. I'll try another one when I get home.
Old Apr 10, 2016 | 07:07 PM
What is its resistance at a few key temperatures? (ambient, fully warmed up, etc.)
Do some investigation. Measure things. "Assuming" that just because a part is "new" is a good way to never figure out what's going on. Parts swapping is a good way to make your car faster by way of weight reduction ... concentrated at the driver's wallet.
Go get a DMM (costs less than a sensor most likely) and find out what's wrong.
Old Apr 11, 2016 | 04:59 PM
Car: 1991 Camaro RS
Sorry for the slow reply. I have an extra sensor from a 5.3 S10 swap. I'll try that and I have a DMM by my side. What am I looking for with it? Sorry for all the questions. I just want my car to idle right...
Old Apr 11, 2016 | 08:14 PM
Car: 1991 Camaro RS
Sofa, I replaced the temp sensor, temp sensor connector, IAC and checked for vacuum leaks. Still no change. Here is what happens. When I start it, I need to hold the gas pedal down. When it warms up I can let off the pedal, but it runs rich and has a high idle. Do you have any ideas?
Old Apr 12, 2016 | 04:52 PM
Sounds like some tuning is in order...
Old Apr 12, 2016 | 05:49 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Maybe check the vacuum line to the MAP
Old Apr 13, 2016 | 05:58 PM
Car: 1991 Camaro RS
I'm going to check again tonight for vacuum leaks and look closer this time.
CamKid1992
Camaros Wanted
Jun 15, 2019 06:41 AM
Michael Harding
Jan 12, 2019 11:11 PM
stegal
Apr 21, 2016 10:25 PM
burnout88
Apr 11, 2016 11:15 AM
Rsd94Z
Mid-West Region
Apr 8, 2016 11:14 AM
