84 plain jane to Better then Iroc. Engine build up. Pic heavy!
Old Apr 21, 2016 | 01:26 PM
Redcreekauto's Avatar
Now we can start getting excited. Engine is coming together!
Attached Thumbnails 84 plain jane to Better then Iroc. Engine build up. Pic heavy!-img_20160420_152711305.jpg   84 plain jane to Better then Iroc. Engine build up. Pic heavy!-img_20160421_093353276.jpg   84 plain jane to Better then Iroc. Engine build up. Pic heavy!-img_20160421_093402030.jpg   84 plain jane to Better then Iroc. Engine build up. Pic heavy!-img_20160421_093434842.jpg   84 plain jane to Better then Iroc. Engine build up. Pic heavy!-img_20160421_114905480_hdr.jpg
Old Apr 21, 2016 | 09:14 PM
Damon's Avatar
Re: 84 plain jane to Better then Iroc. Engine build up. Pic heavy!
Nice. What's the specs on the motor? I assume it's going into something nondescript like a Berlinetta (painted beige).
Old Apr 22, 2016 | 12:02 AM
Its going into a base camaro with a complete Iroc suspension, instrument panel and interior. Black with red interior. Pics of body in progress on the body forum. Scat crank and rods, 30 over pistons, erson cam, Edlebrock intake and carb. I'll get more photos and full specs tomorrow.
Old Apr 23, 2016 | 03:36 PM
Bottom end all together.
Polished aluminum timing cover.
new harmonic balancer assembly.
Old Apr 25, 2016 | 10:39 AM
For those inquiring minds the specs are as follows.
1996 Chevy 4 bolt main truck block bored 30 over.
Scat 383 3.750 stroker forged crank.
5.700" 2.100 Rod journal with bushed pin.
Hyperutectic Pistons - Flat top.
Double Roller timing set.
HV oil pump.
1.5 Roller Rockers.
.548 lift int/exh lift 290/298 duration Erson Cam.
Standard Vortec cylinder heads with minor machining to accommodate springs.
Fully balanced rotating assembly including flex plate and harmonic balancer.
2400-2800 Torque Converter.
Old Jun 21, 2016 | 05:29 PM
https://www.facebook.com/Red-Creek-A...homepage_panel
First run on the engine last night.
91dime
Apr 30, 2016 04:18 PM
astout82
Apr 28, 2016 10:11 PM
hotrodaj
Apr 25, 2016 02:33 PM
Annihilate
Apr 21, 2016 05:37 PM
KoriNoKage
Apr 18, 2016 01:01 PM
