700r4 doesn't shift after tpi to Carb swap
Old May 5, 2016 | 06:37 PM
mdtoren's Avatar
Car: 1986 Iroc Z28
Just finally got my Carb to idle down enough to drive and the trans sticks in 1st gear and won't shift up, even manually all I get is first gear. Would the TV cable completely prevent shifting? I thought it would just give a sloppy delay shift..I have the geometry corrector installed on the carb also.
Help!
Old May 5, 2016 | 06:44 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 700r4 doesn't shift after tpi to Carb swap
Yes. TV cable lets the transmission know where the throttle is at.
Old Jun 30, 2016 | 03:45 PM
mdtoren's Avatar
Car: 1986 Iroc Z28
Resolution to this - I adjusted the TV cable and leveled off the trans fluid, car now shifts perfectly.
802maro
Aug 12, 2016 09:38 PM
Mikeb297
Carburetors
Apr 11, 2016 06:17 PM
moneyman380
Apr 11, 2016 12:24 PM
1982BR
Apr 6, 2016 09:03 PM
kg1922001
Apr 5, 2016 08:22 PM
