Website that takes you STEP by STEP on how to fix flip up headlights?
Old Dec 25, 2001 | 01:34 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
i guess mine are goin out so i need to fix them
so where is a website where it takes me step by step and hopefully some pics of it too....cuz i dont know what all the piece are called or look like
thanks
Old Dec 25, 2001 | 02:09 AM
poorboy8's Avatar
Car: 79 Camaro RS
Engine: 355, carb, alum heads, XE262
Transmission: TH350
Well first off what is wrong with them, be a little more specific. They're really not that hard to fix, I just got done doing my passenger side on my 91 GTA. Basically all youll need is a 1/4" rachet, 2 4" extensions, a 10mm socket (if memory serve me correctly), a swivle/knuckle extension, phillips head screw driver and some torx head drives.
Basically to get the headlight out you have to remove the black trim piece on the front, then pull the headlight, then remove metal piece on the top that goes along with your hood (not sure of the name of the piece but you cant miss it) so when they're flipped down your car doesnt look like doo doo, then there are three bolts at the top and two at the bottom underneath the head light assembly.
Here are some pictures of my stuff if your interested. There kind of big, but will give you an idea of what broke on my car.
http://members.home.net/icu8mydust/9...light%20stuff/
Old Dec 25, 2001 | 09:58 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
well they tell me that my motors or going out on my lights
so i was wondering on how to fix that problem
and you told me how to take the light out right?
thanks for the info
1992CamaroGirl
Dec 25, 2017 08:45 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
DiabolicalRS
Aug 26, 2015 07:35 AM
