suggestions on headwork
Old May 16, 2016 | 01:26 PM
mikeyt's Avatar
Car: 92 Camaro
Axle/Gears: stock
I've got a 92 rs 305 with blown head gaskets. Gonna get the heads worked at a machine shop and was wondering if there's any help to let them breath better. I know porting and polishing of course. Would anybody recommend going with a 1.84 valve in the intake side and shaving 0.020 off the face to help compression?
Old May 16, 2016 | 03:00 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: suggestions on headwork
Take them to the nearest scrap iron place, sell them and find some 081 TPI 305 heads or L30 Vortec 305 heads. Don't waste a dollar on them. They are simply not worth it.
Old May 16, 2016 | 04:56 PM
big hammer's Avatar
Car: 2002 ws6, 2011 sierra 6.2L 6 speed
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
1-- trick flow 175 heads
2--- 305 vortec heads
3--- TPI 305 heads
9,876--- rebuild the stock TBI heads
Old May 16, 2016 | 09:58 PM
mikeyt's Avatar
Car: 92 Camaro
Axle/Gears: stock
How will I know if they are L30 Vortec 305 heads or 081 TPI heads, what do I have to look for-casting numbers, if so what are they? What's better about those?
Old May 16, 2016 | 10:11 PM
mikeyt's Avatar
Car: 92 Camaro
Axle/Gears: stock
Can I use the same rocker arms that are on my current ones?
Old May 16, 2016 | 10:59 PM
mikeyt's Avatar
Car: 92 Camaro
Axle/Gears: stock
Are there certain vehicles that apply i.e. Tahoe, c/k 1500?
Old May 16, 2016 | 11:02 PM
mikeyt's Avatar
Car: 92 Camaro
Axle/Gears: stock
Will a 520 or 059 casting number work?
Old May 16, 2016 | 11:24 PM
mikeyt's Avatar
Car: 92 Camaro
Axle/Gears: stock
The only ones I've found are for 1996-2002
Old May 16, 2016 | 11:41 PM
mikeyt's Avatar
Car: 92 Camaro
Axle/Gears: stock
Finally, do I have to change my intake manifold or can I reuse the stock one since it's a TBI car?
Old May 17, 2016 | 07:04 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
On the Vortecs you can use a Vortec Carb manifold and get an adapter to use your TBI. Lots of people go that route being the Vortec TBI manifold is a bit pricey.The 081s will take your stock manifold.
Old May 17, 2016 | 10:22 PM
mikeyt's Avatar
Car: 92 Camaro
Axle/Gears: stock
Tomorrow, I'm picking up a set of Vortec heads and intake manifold from a 96 c-1500. Will my current tbi work with that manifold or do I need an adapter plate for that also. If so, does anyone know the part number?
project89
Jul 2, 2016 01:08 PM
GMan2012
Aftermarket Product Review
23
Jun 22, 2016 02:03 PM
Formula-Finatic
May 4, 2016 12:06 AM
AW119 Pilot
Pacific Northwest Region
Apr 15, 2016 11:03 PM
HEFF16
Apr 1, 2016 08:18 PM
