No grommet here?
Old May 19, 2016 | 03:44 AM
Firebird2011's Avatar
Car: Pontiac Firebird Formula
Engine: 3.1 LH0
Axle/Gears: Automatic
No grommet here?
Hi guys, I' m wondering if I need a grommet for the PCV. If needed which I have to choose?
Thank you!
Old May 19, 2016 | 07:25 AM
2012sergen11's Avatar
Car: 1987 Trans Am
Re: No grommet here?
I believe the grommet is on the cover in the photo...
unless thats not your car in the photo then that grommet (in the pic) is what my cover has for the pcv
Old May 19, 2016 | 07:34 AM
It does however look like that valve cover is on backwards... PCV valve should be at the front on the driver's side, and the make-up air hose should go to the rear pass side.
The 2 sides of the VC aren't the same. The side that goes toward the intake is more straight up/down than the exhaust side, which is more leaned in at an angle. Putting them on backwards makes the rockers tend to rub, and causes weird ticking noises. Sometimes you can even see the metal moving while the engine is running.
Old May 19, 2016 | 10:20 AM
Engine: 3.1 LH0
Even on a LH0 V6? There's a hard pipe that goes from the intake to the passenger's side cover, maybe is that the right place to connect it?
Old May 19, 2016 | 10:22 AM
Engine: 3.1 LH0
Ok, I always thought that the PCV must have a rubber part on the cover. Thanks!
Xzavior1818
Jul 15, 2016 08:37 PM
That Sky Guy
May 19, 2016 01:05 AM
Motown
May 18, 2016 08:25 AM
GeneL
May 14, 2016 12:43 PM
