have this cams on my shelf, what to use?
Old May 30, 2016 | 07:48 AM
Artic-Trans am's Avatar
Car: 87 TA
Engine: 350 modifyed Stelth Ram
Transmission: 350 rew lock up
Axle/Gears: 9"
ok.
going to give you my dilemma.
I have 3 camshaft to choose form, for my drag race 400 +030 engine 2 bolt mains.
eagle crank, hypereutectic pistons and I-beam rods.
alu heads 210 runners roller rockers. springs are 150/360.
carburator 950
car used only on for drag race 1/8 mile
so my cams I can use is this:
Comp cams 292XFI HR-13 hydraulic roller
adv: 292/300
@050: 242/248
lift: .584/.579
lobe sep: 113
no name CC6F mechanical roller
adv: 305/310
@050: 260/270
lift: .630/.630
lobe sep: 106
melling 22301 Hydraulic flat tappet
adv: 288/288
@050: 232/232
lift: .576/.576
lobe sep: 108
well I tend to use the XFI cam. but would like your opinion!
Old May 30, 2016 | 09:30 AM
Re: have this cams on my shelf, what to use?
The 2nd one looks most suitable to me.
Old May 30, 2016 | 09:59 AM
Car: 87 TA
Axle/Gears: 9"
that is a Doug Herbert Cam.
If I use that one I have to change valve springs, maybe.
Old May 30, 2016 | 09:20 PM
cardo0's Avatar
Car: Fourth Gen '94 camaro
Engine: 350 Gen II
Transmission: A4
What is your compression ratio? The second cam is the better match for a 400 sbc but it needs higher compression. You will need a much higher static compression ratio to get between 8.0 and 8.5 dynamic compression ratio. That when using pump gas.
Good luck.
Old May 31, 2016 | 01:18 AM
Car: 87 TA
Axle/Gears: 9"
my compression is close to 11:1
running VP113 (109okt) fuel
Old May 31, 2016 | 01:57 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
What gearing / trans type / tire size / car weight?
If all of that is right, then the 2nd cam without a doubt.
have to change valve springs?.....yes, more than "maybe".
Old May 31, 2016 | 02:43 PM
Car: 87 TA
Axle/Gears: 9"
car is 1200-1300 kg
tires 32 inch high
rear end 5.80
powerglide trans.
you all like the cam I am afraid is going to put my crank down on track.
remember this is a 2 bolt block.
Old Jun 1, 2016 | 06:33 AM
86LG4Bird's Avatar
OK, then I'd be thinking of the XFI cam and limit the revs to about 6500.
You'll still need a stout valvetrain and 150 psi on the seat for those XFI lobes.
Old Jun 1, 2016 | 08:18 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
X2 Mech roller, change springs, will need solid lifters
And stud the mains it wont drop the crank, its not gonna need much higher than 6500-6700 rpm either
If you went xfi hyd roller still need to change springs
Old Jun 1, 2016 | 09:44 AM
86LG4Bird's Avatar
..and what torque converter are you running?
very important factor, especially for 1/8th mile.
Old Jun 3, 2016 | 08:06 AM
Car: 87 TA
Axle/Gears: 9"
my corverter is a Hughes Performance Pro II
I am happy with this one so far.
about the 1/8 mile, there will be some 1/4 mile also, with a different rear end.
kenney001
Apr 13, 2016 11:58 AM
::Andy::
Apr 7, 2016 03:30 PM
Piston454
Apr 6, 2016 01:06 PM
Piston454
Mar 31, 2016 06:39 PM
kyrophis
Mar 20, 2016 03:33 PM
