need help pulling my cam
Old Jun 3, 2016 | 12:03 PM
bensbaby's Avatar
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
I have a 1988 gta
im pulling the factory cam now as we speak
I cant get it to budge
everything is out
it should just pull out and its not.
does any have any ideas
Old Jun 3, 2016 | 02:45 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: need help pulling my cam
Originally Posted by bensbaby
I have a 1988 gta
everything is out
When you say "everything" , that includes all 16 lifters , the distributor , and the camshaft retaining piece that's under the camshaft's drive sprocket that bolts to the block with a couple or three bolts , yes ?
If so , there should be nothing else holding you back from sliding it out , provided it's not rusted stuck to it's bearings and can't turn ? Or sludged in to the point of being almost glued in place ? If it turns free and all the above is removed I can't see why it shouldn't slide out .
Have you tried bolting the sprocket back on and using that to get good enough of a grip to give a good tug on it ?
Old Jun 4, 2016 | 09:00 AM
zraffz's Avatar
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
If everything is out, does it spin freely?
I had a machine shop assemble a long block for my brother because I was too busy and they never verified cam bearing clearances... that cam would not spin or slide.
Old Jun 4, 2016 | 05:59 PM
bensbaby's Avatar
Engine: 383 built
yes and ty it was stuck on my dist
my bad
im retarted as soon as I took it out it slide right out ...
ty again
Old Jun 4, 2016 | 06:25 PM
big hammer's Avatar
Car: 2002 ws6, 2011 sierra 6.2L 6 speed
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
How did you have the lifters out with the distributor in...
Old Jun 4, 2016 | 06:31 PM
OrangeBird's Avatar
Car: 1989 Firebird
my bad
ty again
Your Welcome .
A very good question indeed , since untill the distributor comes out the intake manifold can't come off , and I see no other way to remove the lifters till the manifold is out of the way ?
