I need help!!!
Old Jun 6, 2016 | 07:04 PM
WildZubat's Avatar
I need help!!!
Okay so I have a 89 firebird I did a engine swap I have a 350 vortec all stock with a 625cfm street demon carb I have about 4500 miles on it and its been sputtering when I press on the gas so I had Just copper ac delco plugs in there and needed to do a plug change anyways so the guy at the counter said I should get the platinum plugs since its carbed I put them in it stopped doing it for about a day and now its doing it again my next step is going to change the fuel filter to see if its clogged and go from there can you guys let me know what you think!!!
Old Jun 6, 2016 | 08:01 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: I need help!!!
The other plugs would have been fine. If it was fine after changing the plugs and shortly after it started to do it again, what do the recently replaced plugs look like? It sounds like they are fouling out pretty quickly.
acerulz
Carburetors
Mar 30, 2016 09:04 AM
sdmf1383
Carburetors
Mar 28, 2016 08:45 PM
brettr81
Mar 28, 2016 05:20 PM
mclenty0
Mar 19, 2016 11:36 AM
BeyondZ28_85
Mar 16, 2016 06:34 PM
