Timing chain differences
Old Jun 11, 2016 | 06:20 PM
moneyman380's Avatar
Car: 1991 Z28
I'm helping a buddy on his 92 350 with a cam swap and recommended he replace the timing set too. But I'm having trouble understanding the difference between a roller cam one and pre 86 one. Alot of the ones I've looked at say they are not for factory roller cam motors. Also the guy at my local oriely auto gave my buddy one that says on the manufacturers website will not work. So whats the difference for a roller and non roller sprocket setup?
Old Jun 11, 2016 | 06:39 PM
Re: Timing chain differences
The bolt pattern on the front of the cam is different: the roller cam one, the bolts are REAL CLOSE together. Also the bore for the cam nose is smaller. Gotta be that way to fit inside the retainer plate.
Crank gear & chain are the same.
Old Jun 11, 2016 | 08:12 PM
Car: 1991 Z28
Thank you.
Old Jun 11, 2016 | 10:26 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Normal flat tappet cams are automatically forced into the block when the engine is running. With a roller cam, there needs to be a retainer to hold the cam into the block. For a non roller block with a roller cam installed, there's a button that fits in the end of the cam gear that presses against the timing chain cover to keep the cam pushed into the block.
As already mentioned, if the cam requires a retaining plate, it will use a different timing chain set.
91 camaro racer
Apr 1, 2016 04:41 PM
liquidh8
Mar 29, 2016 07:51 AM
xkingcodex
Exterior Parts Wanted
Mar 22, 2016 01:45 AM
upon2
Mar 20, 2016 09:09 PM
5.7RamJet
Aftermarket Vendor Review
Mar 19, 2016 06:38 PM
