Distributor recommendation
Old Jun 12, 2016 | 08:20 AM
Flip33's Avatar
Car: 1933 Ford Sedan, 1934 Ford Pickup
Engine: 350 Chevy
Transmission: 700 r 4
I am converting a L-31 (1996) to a carb. Will be run in a pretty much stock engine in a 34 Ford hot rod PU. Would like some Dizzy recommendations. Also would it be OK to run my orginal dist. gear on the new dist? Thanks in advance
Old Jun 12, 2016 | 10:04 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Distributor recommendation
A stock large cap HEI is the simplest system to install. It's a self contained system all under the cap.
If you're after some bling, a basic MSD will work too but you would also need to buy some sort of ignition box/module.
Flip33
May 8, 2016 11:44 AM
blacksunshine'91
Interior Parts Wanted
Apr 29, 2016 11:07 PM
KoriNoKage
Apr 18, 2016 01:01 PM
kknight5
Apr 15, 2016 05:34 AM
propaintball96
Apr 12, 2016 01:30 PM
