Possilby a dumb dipstick question!
Old Jun 17, 2016 | 07:35 AM
Abubaca's Avatar
So as my build progresses, I've kinda pushed back some easier/smaller fish.As I get closer to finishing, I need to address those things. For example, I need a dipstick. ....as I look on all the various websites, none seem to take into account what kind of oil pan you have. I have a moroso 7qt. so does that mean I need a special dipstick since the dimensions are definitely not stock? Logically I would think every pan would require a different dipstick based on how deep it was. ......or am I simply overcomplicating this.
....oh, and does it matter if it's driver side or passenger side? I'm assuming that refers to how the tube is bent, and how it bolts to a stock manifold or head bolt. All of which are NOT stock on my motor, so I'll have to rig something up, right?
Old Jun 17, 2016 | 12:41 PM
MSgt Luttrell's Avatar
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
Re: Possilby a dumb dipstick question!
To my knowledge all the after market oil pans are designed so that a stock oil dipstick will read correctly.
Old Jun 17, 2016 | 01:25 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
The dipstick is right or left depending on what block you have.
Most aftermarket dipsticks are close but not quite in accuracy.
I Put the correct amount of oil in the pan and then put in the dipstick. Remove it and put the new full line on the backside with a grinding disk if needed..
Old Jun 17, 2016 | 02:51 PM
Abubaca's Avatar
TTOP350, THAT....is an awesome....and completely logical idea!!!!!
Old Jun 17, 2016 | 05:35 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
I went with the Lokar knock off offered by summit and the stick was shorter because the tube was shorter. I always figured it had to do with the type of engine and stick location.
Old Jun 17, 2016 | 07:54 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
I got the Lokar it was a breeze to install.
J-money
Apr 10, 2016 08:43 AM
Donald Croes
Apr 4, 2016 03:18 PM
gmancamp
Interior Parts Wanted
Mar 31, 2016 03:47 PM
89 formula TPI
Mar 28, 2016 08:01 AM
soulreaper
Mar 26, 2016 06:36 PM
