Red Hot headers and boiling coolant!!
Old Jun 19, 2016 | 09:33 AM
patricktroyz28's Avatar
Car: 1991 Z-28
Transmission: 4L60
Total loss. Did a easy swap of a ported Intake manifold, new fuel injectors (still 19LB) and ported new runners. Ran perfect before swap.
Now the RPM race all over the place, and within 2 minutes the headers are red hot and coolant is bubbling in the overflow tank.
Took it apart twice and put it back together.
Timing is dead on. Even removed the timing cover. Tried different advance/retard no luck. Changed from aftermarket to stock chip no difference. Power to the ECU. no vacuum leaks. No codes.
1991 Z 305 TPI auto, original cam. Only mods besides this are headers/exhaust/TB...all done years prior to this swap.
ANY suggestions welcome!!
Old Jun 19, 2016 | 09:53 AM
big hammer's Avatar
Car: 2002 ws6, 2011 sierra 6.2L 6 speed
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
Re: Red Hot headers and boiling coolant!!
Some Intake gaskets have coolant port blocks. If you put those to the front that will happen.
Old Jun 19, 2016 | 09:57 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Sounds like its super lean or a BIG vacuum leak. I've heard people say that have no leaks and turns out they did. I'd use a homemade smoke machine to test that. http://www.r3vlimited.com/board/showthread.php?t=274418
Check your fuel pressure and I wouldn't rule out the injectors being bad.
And as Big Hammer pointed out, if you took the manifold off the block you could've put the gaskets on wrong.
Car: 1991 Z-28
Transmission: 4L60
Thanks big hammer....not aware of that..will check again on next tear down!
Any other suggestions/experience's welcomed
Old Jun 19, 2016 | 10:01 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
What is your timing set at?
Old Jun 19, 2016 | 10:02 AM
Car: 1991 Z-28
Transmission: 4L60
Good feedback on the homemake smoke aliceempire....thanks!
Old Jun 19, 2016 | 10:04 AM
big hammer's Avatar
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
When you say that you removed the timing cover... Were you adjusting the cam timing or ignition timing?
Old Jun 19, 2016 | 10:12 AM
big hammer's Avatar
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
If you never unplugged that timing wire when you set your timing, it will be set quite retarded. This causes a pile of heat to enter your headers and coolant system.
Old Jun 19, 2016 | 10:17 AM
Car: 1991 Z-28
Transmission: 4L60
Hi BigH...yes I unplugged that. Have set the timing to 6degrees before. And tried every setting on the timing after with cable and cable unplugged. Removed the timing cover and #1 sparkplug just to make sure it was deal on.
Old Jun 19, 2016 | 10:20 AM
big hammer's Avatar
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
If you're using an advance timing light make sure it's set on zero.
Old Jun 19, 2016 | 10:27 AM
big hammer's Avatar
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
Just thinking out loud... If all the header pipes are glowing hot it sounds like retarded timing. If it's only a few you might have a couple plug wires messed up.
Still look for vacuum leaks too
Old Jun 19, 2016 | 10:38 AM
Car: 1991 Z-28
Transmission: 4L60
Good for thinking out loud! Cause I'm frustrated ha. Yes plug wiring is correct..even drew it out on a piece of paper from my manuals..then took a blank piece of paper and went to the garage and drew it out...just to make sure I was not having a brain cramp.
Advanced timing light also indicates dead on. I'm sure timing is not an issue. Have tried all different degrees on the tab and little to no effect on the main issues. They are Hooker ceramics 2055, and I know they run abit hotter, but are blood red in a minute, and coolant bubbling in the O/F.
Old Jun 19, 2016 | 10:40 AM
Car: 1991 Z-28
Transmission: 4L60
thanks for the help so far folks!
Old Jun 19, 2016 | 11:04 AM
Problem is ignition timing. Pure and simple. Don't protest; the problem is ignition timing. It's retarded. ALOT.
Put down the light, and just advance it about 30°.
See what happens. It works like this:
Adjust it.
Better/worse?
Better: adjust it some more the same way.
Worse: adjust it back to where it was, and a little bit more.
Better/worse?
Better/worse?
Better/worse?
Better/worse?
Better/worse?
Better/worse?
Better/worse?
Presently you will come to a place where no further adjustment makes it "better". In the case of ignition timing, "better" might be any combination of attributes that are affected by it, such as gas mileage, crisp throttle response, cool running temp, freedom from pinging under all but the most extreme conditions, cool exhaust temps, and so on. At that point, you have just made that one particular thing AS GOOD AS IT GETS; no further improvement is possible. And best of all, YOU get to pick the attributes of YOUR car's performance that are most important to YOU while YOU are using YOUR car the way YOU use it where YOU live with the fuel YOU put in it. YOU are in control, not "book" and "spec".
NOW, since after doing this your car will be running AS GOOD AS IT POSSIBLY CAN by making that particular adjustment, you may pick your "light" back up, and see WHERE IT IS; and next time somebody thinks THEY know better what YOUR ENGINE wants than YOUR ENGINE does, you will know right where to put it back to.
We call this process "tuning". Of course you can get much greater control over more things by "burning" "chip"; but as far as a mechanical setting, you just maxed it out.
If I may paraphrase one of The Great Ones in a COMPLETELY unrelated field, but whose wisdom (much like my signature) is so widely applicable as to be almost universal, ....
"If it RUNS good, it IS good".
NEVER forget that. It's so simple it hurts. It just WORKS. Don't outsmart yourself over something that blindingly obvious.
Old Jun 19, 2016 | 11:12 AM
Car: 1991 Z-28
Transmission: 4L60
Tks Sofakingdom for the detail on that post and taking time to do it. Ill be doing everything here so far suggested and post results...so guys rock as usual
Old Jun 19, 2016 | 11:54 AM
big hammer's Avatar
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
GM made different timing covers and balancers with the marks in different places. If you have a Mis matched set your timing could be way retarded but show that it's good.
Old Jun 19, 2016 | 12:07 PM
Car: 1991 Z-28
Transmission: 4L60
Good point big hammer. Still original cause I am the original owner
Old Jun 19, 2016 | 12:12 PM
big hammer's Avatar
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
Then with the timing wire hooked up, keep turning the distributor counter clockwise until the engine quits revving higher. Then back it off a touch. Let it idle and see if it still overheats.
Old Jun 19, 2016 | 12:58 PM
OrangeBird's Avatar
Car: 1989 Firebird
If you are the original owner , then you should know if the Harmonic Dampener has ever been replaced . Has it ?
I ask this because it's a known failure that the rubber between the hub and the outside weight (where your timing mark is !) dries out and allows the outer ring to slip on the hub with the result of your timing marks being out of sync with what's actually going on , timing wise . I offer this up just as one possible scenario of why the factory timing marks could be tellin ya lies .
Bottom line = cherry red headers means fuel burning in the exhaust and like the guys have said , retarded (late) timing is the #1 culprit of this on an otherwise healthy* engine .....
* leaking or misadjusted (too tight so as to keep the valve from fully closing) exhaust valves can cause this also , did you alter any of the valve clearances during this manifold install , possibly getting them too tight ?
Old Jun 19, 2016 | 03:27 PM
Car: 1991 Z-28
Transmission: 4L60
Orangebird, thanks! We did look at the Harmonic Dampener and it is original one, and is starting to show what u speak of, but not close to failure mode for a few years yet.
I did not do anything else, except straight replace of the bolt on parts. Was looking at the old intake and could have very easily blocked a cooling port. Pic there with a red pencil in the cooling port, and blank at other end. Quite easily could have the gasket blocking it as I never thought about that and was really focused on a nice clean work area on the engine for a good seal and looking at the intake ports only...the gaskets would fit perfectly blocking intake and exit of coolant.
Gonna do the 30 advance timing first and vacuum smoke job, and failing that, strip down to check that gasket.
Gotta funny feeling its the gasket blocking a cooling port.
Old Jun 19, 2016 | 06:19 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
you could pull your upper radiator hose of at the rad,...start it up, and see if water flows after the thermostat opens. that would tell ya if the intake gaskets are on backwards. i kinda think its your issue, but you never know.
Old Jun 19, 2016 | 06:21 PM
MSgt Luttrell's Avatar
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
Most of the time when the exhaust is glowing red, it's bad timing, but I have seen spark plugs gapped way too low cause it as well.
Old Jun 19, 2016 | 06:31 PM
big hammer's Avatar
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
Considering where the thermostat housing is on a TPI, you might be able to drain some coolant and remove the thermostat housing and look on there to see if the ports are blocked
Old Jun 19, 2016 | 06:55 PM
The ports probably aren't blocked.
But that aside:
Read my signature. Pay attention to EVERY WORD.
"The simplest explanation that fits all the facts is usually the right one".
How does ANY proposed explanation that involves coolant passages, fit ALL THE FACTS? How does that account for red-hot headers?
Leave the coolant passages alone. Not saying they're "good"; not saying they're "not blocked"; not saying "you did the gasket right"; not saying "the gasket can't block the port". What I AM saying is, a farkled gasket DOES NOT fit ALL the facts, and therefore, should be ruled out as the cause of the cluster of symptoms you report.
NOTHING about the cooling system accounts for that, in fact. NOTHING. Again, I'm not telling you your cooling system is "perfect", there's "nothing wrong with your cooling system", or ANYTHING of the kind; only, THE COOLING SYSTEM CANNOT CAUSE WHAT'S HAPPENING. Leave it alone and devote your mental effort to things that CAN. Then once you have the immediate problem straightened out, if the cooling system still seems inadequate, THEN AND ONLY THEN, go back and dink with it. BUT NOT NOW.
Your problem is ignition timing. Quit posting on the Internet, quit accepting people who want to divert you down non-productive rabbit holes, quit thinking that just because "light" and "mark", the timing is right. IT'S NOT. Go crank it around A BUNCH; 30° is probably not enough to restore it to "right". But should be enough to tell you, whoaaaaaa, this was REALLY messed up, with a capital F.
Be logical. Go do it. Mark it first if you don't believe me so you can put it back. You won't want to do that though, you'll amaze yourself at how something so simple can have such far-reaching effects.
Old Jun 19, 2016 | 07:08 PM
big hammer's Avatar
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
But that aside:
You could have saved the panic attack if you just read a little better man
Old Jun 19, 2016 | 07:16 PM
No panic attack; just some REALITY. Just trying to help keep you from wasting d00d's time on the cooling system. Specifically, because NOTHING about that accounts for ALL THE FACTS; in this case, red-hot headers.
Old Jun 19, 2016 | 07:18 PM
big hammer's Avatar
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
He already said he's going to do the timing then vacuum leaks first bud. Then look into the gaskets if all else fails.
Old Jun 19, 2016 | 07:28 PM
In the meantime, he doesn't need to hear about gaskets. He needs help and encouragement to direct him TOWARD the problem, not AWAY FROM it.
Let's help him out: leave off talk about gaskets until he fixes the problem he ACTUALLY HAS. Then, maybe if there's still something wrong, we can revisit the other.
Old Jun 19, 2016 | 07:34 PM
big hammer's Avatar
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
You his mom?
Old Jun 19, 2016 | 07:39 PM
Car: 1991 Z-28
Transmission: 4L60
Back to topic Good debate...love passion! Thanks for the input and the timing is gonna be the first target!
Old Jun 19, 2016 | 07:44 PM
It's a mental art.
We call it FOCUS.
Patrick, let us know how it turns out when you advance the ignition timing. Pretty sure that's THE WHOLE problem, and you'll get it fixed without touching the cooling system.
Old Jun 19, 2016 | 07:47 PM
Car: 1991 Z-28
Transmission: 4L60
100% and thanks for the feedback! I had nothing today and a little frustrated of course! Thanks all for your time!
Old Jun 19, 2016 | 08:58 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
You'll be alright. Sofa is right, glowing headers means retarded timing. There is no teardown in your future, lol
Old Jun 26, 2016 | 02:26 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Any updates?
Old Jul 10, 2016 | 06:02 PM
Car: 1991 Z-28
Transmission: 4L60
OK folks, sorry for the late update! Never had much luck, so proceeded to haul it apart, and found the culprit.
You see in pic that the intake manifold gasket for the runner would look ok, as the Edelbrock only had the little hole and the gasket surrounded it. good to go with the Edelbrock runners! Well you can see the black marks from air being sucked in..not good to go after all.
I never tried the gasket against the runner, and you can see not a match at all in the other pic. 99.9% sure this is all my issues. In rebuilding phase now.
Be checking gaskets on both sides from now on!!
Old Jul 10, 2016 | 08:01 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
This would explain your high erratic idle, that's a pretty bad vacuum leak. But it wouldn't explain your red hot exhaust. It's been a while since I've had a TPI intake apart, but I think that small hole beside the runners is the EGR passage...
Old Jul 10, 2016 | 08:21 PM
TTOP350's Avatar
Looks like the wrong gasket there. How is the gasket on the otherside?
Old Jul 10, 2016 | 09:11 PM
Car: 1991 Z-28
Transmission: 4L60
gasket perfect on the other side. Gaskets were perfect for stock runners, not so much the Edelbrock.
So I figure trying to do timing with this leak was impossible, so I just have it way off. I went from 30 degrees right to the other side of the spectrum, and I was either revving like crazy or stalling.
Rebuilding almost complete and will update all for the input!
Old Jul 10, 2016 | 09:15 PM
TTOP350's Avatar
Are those Mr gasket brand? I recently had issues like this with them, there were a few gaskets that were wrong in my package.
Old Jul 10, 2016 | 09:22 PM
RC1's Avatar
RC1
Car: 86 CAMARO SC
Although the gaskets aren't correct, you're going to find that's still not the issue, even though when you put it back together you may correct the real problem which was timing. When you said that the idle went way up when you adjusted the timing, that would've corrected the glowing header issue. Good find with the gaskets though.
Old Jul 11, 2016 | 09:22 PM
Car: 1991 Z-28
Transmission: 4L60
Yes they are Mr Gasket! So did a much more careful rebuild (cause I'm not a mechanic!!) and presto....everything dead on working perfect.
I really really really blamed the timing, even as the timing gun was dead on, and the idle was like anywhere from 3000 to stalling out on the retard, boiling antifreeze and red hot headers. Even to the point to taking off the timing cover, wondering if the balancer had slipped etc.
But at the end of the day, that open port to the EGR passage caused all of this.
Thanks all for the input and I have learned a lot from this...still not a mechanic but learning!
Old Jul 12, 2016 | 10:10 AM
  #42
I thought that might be the source of the rpm's racing up. Vacuum leaks on a tpi manifold can be really hard to find even when they're that big of a leak. Glad you got it.
Rider91
May 22, 2017 12:34 PM
Chf.BurninGlass
Jul 10, 2016 12:07 AM
'91CamaroRS
Mar 29, 2016 06:42 PM
scarr001
Mar 25, 2016 10:50 AM
1988
Mar 24, 2016 08:09 AM
