how to test fuel injectors
Old Mar 21, 2016 | 08:51 PM
Rider91's Avatar
i need a step by step run-through on how to test my fuel injectors to be sure i need to get a new set, ive already looked up new ones on south bay fuel injectors.
88 camaro 305 tpi auto.
also if/when i order injectors should i also replace pressure regulator or stick with the old one?
and if i do order the new pressure regulator from south bay does it come pre-adjusted or will i have to adjust it myself?
Old Mar 22, 2016 | 09:00 AM
Jared Garner's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 L98
Transmission: TH700R4
Re: how to test fuel injectors
Try this link.
If memory serves correctly, you should be reading about 14-17 ohms, less than that and they're going out or just bad.
Old May 21, 2017 | 01:08 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Might look into a pulse tester kit. Not a lot of money and will test the flow through the individual injectors. Pulses them one at a time for 10 or so pulses and you look at the pressure drop on the fuel rail. Pretty handy little device.
Old May 21, 2017 | 03:51 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
I bought one of these just to examine it, simply because it was so cheap:
Amazon Amazon
It got it off an ebay seller for less than $20 shipped; IIRC, it was shipped from China.
I've never tried to use it because I didn't have a handy way of plugging it into a Bosch injector connector. It doesn't appear to be typical of Made in China stuff. But I didn't open it up and look inside of it either.
I have an OTC injector tester that I normally use instead (
Amazon Amazon
When used with a fuel pressure gauge, these things are very handy tools to have.
Old May 22, 2017 | 12:34 PM
southbay08's Avatar
definitely check the resistance as the stock injectors are notorious for coil failure. If they check out at 12ohms or less they need to be replaced. Or if you want....send them in and we'll put them up on the bench. If they check out fine we'll just send them back to you and all you will have to do is pay shipping. If they don't work we can get you a set of bosch lll's. It's up to you
BlueZee28
Mar 17, 2016 08:45 PM
rlthrasher
Feb 26, 2016 10:05 PM
Carystone92
Feb 23, 2016 07:33 AM
customblackbird
Feb 22, 2016 05:09 PM
rats85z28
Feb 22, 2016 08:43 AM
