What headers are you using
Old Jun 20, 2016 | 11:16 AM
amshnock's Avatar
What headers are you using on your camaro. I have a 88 iroc with a 292 512 Cam and need so nice flow headers looking for some that I don't need to cut or bend. Looking for bolt on .
This was a tbi car being swapped to carb
Old Jun 20, 2016 | 11:22 AM
WickedBowtie's Avatar
Car: 1989 Camaro RS
Engine: 383
Transmission: TH400
Axle/Gears: 9 inch, 35 spline drag spool,4.56
Re: What headers are you using
Hedman has a decent set for the price. They bolt right in in automatics. Think they have to be modified on a MT to make work or don't work at all.
Old Jun 20, 2016 | 12:31 PM
amshnock's Avatar
Thank you I will look in to it.
My trans is a auto 700r4 with a 2800 stall.
Old Jun 23, 2016 | 04:00 PM
amshnock's Avatar
Think this will be a good fit?
https://m.summitracing.com/parts/hed-68470
Old Jun 23, 2016 | 07:24 PM
Car: 1989 Camaro RS
Engine: 383
Transmission: TH400
Absolutely...if you want to run shortys.
Old Jun 23, 2016 | 10:20 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
These are the best 1 3/4" shorty headers made. Dyno Don's headers and Y pipe fit great and are custom made. http://www.top-downsolutions.com/powertrain-performance
Old Jun 24, 2016 | 11:14 AM
amshnock's Avatar
I really don't want to spend more then 300 on headers. I had a price limit doing this car and I'm vary close after doing the motor.
Also dip stick is in driver side I know that's a factor.
Old Jun 24, 2016 | 03:54 PM
red rock's Avatar
Car: 1987 iroc
That wasn't stated anywhere in your post. I wouldn't have posted anything if you were looking to go cheap. Cheap is out there everywhere, but you get what you pay for also.
Old Jun 24, 2016 | 11:20 PM
mikeyt's Avatar
Car: 92 Camaro
Axle/Gears: stock
Are you trying to reuse your stock y pipe or changing both? A good set of coated headers and y pipe is going to run you around $800. The painted ones usually flake and come off and rust in around a year, as far as the stainless I'm not sure.
Old Jun 25, 2016 | 11:49 AM
amshnock's Avatar
I know I should of said something about prices.
I don't have to reuse stock y pipe but would be nice. Just need a cheap set of headers with out have to cut or mode anything just to get my car going until I can get a nice set.
Team89RSCamaro
Apr 9, 2016 05:20 PM
Donald Croes
Apr 4, 2016 03:18 PM
jdhh74
Apr 1, 2016 05:50 PM
Bradsaundry
Apr 1, 2016 01:42 PM
Dfdub92
Mar 28, 2016 09:47 PM
