vibration test.....
Old Dec 26, 2001 | 04:48 PM
Blade69's Avatar
vibration test.....
how can i tell when my car vibrates at 3500RPM in ever gear, is coming from the crank, the flywheel or the driveshaft on a 84 Z28 5-speed?
Old Dec 26, 2001 | 11:07 PM
CODY BEHNKE's Avatar
Did you recently do any clutch work? My Formula had ths problem but at 4000rpm. It was a clutch/flywheel balance problem.
Old Dec 26, 2001 | 11:10 PM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
you can elim the driveshaft if its in each gear, at 3500 depending on which trans you have the drivshaft will be turning anywhere from less than 1000 to more than 4000 (if its a OD trans)
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
