Please help need input on the value
Old Jul 10, 2016 | 03:27 PM
Jstewart1021's Avatar
Want a title? Post!
I would love you guys input prior to purchasing this vehicle tomorrow. I'm not sure of the value as I can not seem to find one that seems correct. You comments and opinions are greatly appreciated. Here are the specs and history.
1992 Camaro convertible RS
I am purchasing it from the second owner who purchased it from his friend in 1997 with 30k miles. Right now the car has 49k original miles on it. The car has always been garaged and keep in Southern California. The odometer had to be repaired at the Chevy dealership about 700miles ago and it appears to be in line with what was reported through car fax
The car fax is clean the car is all original including paint.
The paint has a couple dozen small chips on the hood and front from normal use over the years but it still shinny and smooth. It does not look like it has been in any accidents or had any body work done to it (the owner confirms this to be true).
The front spoiler is scratched and looks to be touched up with a non matching paint (owner says his friend did that prior to him purchasing it).
The interior is impeccable no tears cracks stains ect
The top is in great shape and does not leak. The back plastic window does have some discolor on it (do I have to replace or can that be cleaned).
The motor runs well it seems to have some sort of exhaust leak I'm sure that's not to much to fix.
The front end makes a little bit of rattle noise while going through a bumpy area (maybe the bushing need to be replaced?) but it handles good.
The trunk shocks need to be replace as the truck does not stay up
Both windows roll up and down slow (maybe the motors need to be replaced)
Front tires are the original tires and need to be replaced
Again thanks for you input I would like to know what I should pay for this
SpectroRacing
31
Sep 18, 2020 12:30 AM
notrabies
Jul 29, 2016 09:39 PM
edpontiac91
Apr 1, 2016 01:25 PM
gnilson
Mar 24, 2016 02:44 PM
87cam305
Mar 17, 2016 11:27 AM
