Vacuum Line Kit???
Car: 1987 IROC-Z
Engine: 5.7L TPI
Axle/Gears: Borg Warner 9 bolt with 3.27
Vacuum Line Kit???
Anyone know if there is a complete kit to replace all the vacuum lines on a TPI 350? Looks like many of the lines are original and very suspect. Thanks.
Car: 88GTA
Engine: 5.7TPI
Re: Vacuum Line Kit???
The hard pre-formed plastic tubing will be hard to find. The rubber hose can be had at the local auto parts store. Just get various sizes and run new.
The pre-formed plastic tubing is EEEEEEEEEZY.
Just buy it in bulk at AZ or wherever, and hold it in the shape you want and wave a heat gun or propane torch over it lightly.
You can make lines that are indistinguishable from factory that way if you're careful.
yevgenievich
Jul 18, 2016 07:47 AM
