Ignition on source
Old Jul 25, 2016 | 03:56 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Ignition on source
92 Z28 5.7
Where is there a good wire, preferably on the passenger side under the hood, to tap into to get a run signal (not always hot)
I didnt want to run a wire thru the firewall to the ECM. If there is anything under the hood that is safe that would be awesome
Old Jul 25, 2016 | 09:09 PM
mikeyt's Avatar
Car: 92 Camaro
Axle/Gears: stock
Re: Ignition on source
I'd like the same thing, I don't want to run through the firewall if I can help it for my aftermarket cooling fan.
Old Jul 26, 2016 | 10:55 AM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
I never found one I liked.
I pretty easily did an addafuse to the fuse block in the drivers footwell.
Ran it across the dash and out just under the antenna grommet. Through the fender and right up below the AC box.
Old Jul 26, 2016 | 01:54 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally Posted by Pro
92 Z28 5.7
If you want something that is hot in the run position, but cold in the cranking position, there are four locations to grab a hot wire. There is a pink w/black stripe at the AIR system valves (2), the CCP solenoid, and the EGR solenoid. They are on the 10A GAGES fuse.
RBob.
Old Jul 26, 2016 | 03:47 PM
Abubaca's Avatar
Does anyone know if the fusebox under the driver side footwell is hot in the cranking position? ...battery isn't in the car, and I need to add a fuse like Vanilla did.
Sorry for the hijack.
Old Jul 26, 2016 | 06:47 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
RBob.
Sweet, pink/black to the charcoal canister is perfect. I just tapped off that. I didnt wanna take the intake off just to get the the EGR junk. Plus the temperature probe out of the radiator fins is on the drivers side anyway, so i just ran them together.
Piston454
May 31, 2016 12:04 PM
Chough262
Apr 10, 2016 01:20 PM
gmancamp
Interior Parts Wanted
Mar 31, 2016 03:47 PM
gwman
Aftermarket Product Review
May 15, 2001 05:20 PM
88'camaro305TBI
Mar 12, 2001 06:47 PM
