Water pump
Old Aug 1, 2016 | 10:27 PM
Anthony0128's Avatar
Water pump
I was replacing my water pump and I don't know if I should remove the water in the engine, is water suppose to be there and should I remove it or not ?
Old Aug 1, 2016 | 10:30 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Water pump
Anytime you remove a cooling system component, expect coolant to come out. Just draining the radiator should minimize the flood.
Old Aug 1, 2016 | 10:40 PM
Re: Water pump
But in the engine is there water? And do I have to remove it ?
Old Aug 2, 2016 | 06:31 AM
Re: Water pump
Yes there is coolant in the engine.
No you don't "have to" remove it. It will remove itself when you pull off the pump, if you don't take care of it beforehand. You may however "have to" clean up the mess afterwards though.
Old Aug 2, 2016 | 02:22 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Re: Water pump
This article may help answer some questions:
http://garage.grumpysperformance.com...ks-basics.853/
It's a bit TMI, but the basics are there. Some cool photographs and diagrams too.
JunJun
May 23, 2016 09:55 PM
Slowridr
May 23, 2016 10:22 AM
Hawkeye1980
May 11, 2016 12:07 PM
Ezrider83
May 10, 2016 03:10 PM
rusty vango
May 10, 2016 02:12 PM
