Need help with valve adjustment orientation...I'll explain
Car: 92 Camaro
Axle/Gears: stock
I've got a 92rs 305. I put new remanned heads on it and want to make sure I'm adjusting the valves correctly since the Haynes manual doesn't give great instruction. Standing infront of the car with 1,3,5,7 on driver side 2,4,6,8 on passenger side is the orientation like this-not the procedure:
1ei, 3ie, 5ie, 7ei
2ei, 4ie, 6ie, 8ei
The procedure in the book seems ok, just want to make sure I'm adjusting the right valves on the right stroke.
1ei, 3ie, 5ie, 7ei
2ei, 4ie, 6ie, 8ei
Re: Need help with valve adjustment orientation...I'll explain
No that is not correct.
The valves are EIIEEIIE on each side. (the 2 sides are identical... after all, the heads interchange)
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
If the Haynes manual is that incorrect, let's review which valves get adjusted at TDC #1 compression.
At TDC #1 compression adjust the following valves:
Exhaust: 1, 3, 4, 8
Intake: 1, 2, 5, 7
Turning the crankshaft one rotation so that the timing mark lines up at zero-degrees (TDC #6 compression) adjust the following valves:
Exhaust: 2, 5, 6, 7
Intake: 3, 4, 6, 8
Exhaust: 1, 3, 4, 8
Intake: 1, 2, 5, 7
Exhaust: 2, 5, 6, 7
Intake: 3, 4, 6, 8
