Would this help?
Old Aug 21, 2016 | 07:09 AM
w41duvernay's Avatar
Car: 1986 Pontiac Firebird s/e
Engine: 305 Chevy
Axle/Gears: 2.77 for now
Would this help?
Sirs,
I have a 1986 Firebird s/e that I brought off of an old lady 130k, with the Lg4 305. I installed a Comp Cam 260 H cam, and started it up. Of course, I expected to run with a lope , and it popped a check engine light. I was wondering if switching to a L69 computer of the same year would help adapt the car to aftermarket cam. I am planning on a few standard mods as well, long tube headers, and new 3" single exhaust, and I do already have an Edelbrock performer intake on her as well. The stock Lg4 cam had 179 duration @ .050s, and this Comp Cam has 212 @ .050s.
I'm trying to have this car running with NO check engine lights, so I can sell it quick.
Old Aug 21, 2016 | 09:49 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Would this help?
Put the original cam back in?
Old Aug 21, 2016 | 10:03 AM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
the ecm isn't going to see what it wants to see with that cam, you're better off ditching the ecm and going with a non ecm controlled carb
Old Aug 21, 2016 | 10:26 AM
OrangeBird's Avatar
Car: 1989 Firebird
Old Aug 21, 2016 | 11:40 AM
Engine: 305 Chevy
Naf,
I don't know what happened to peanut cam. It's gone. I want to try to go to a mid 80's HO ecm.
Old Aug 21, 2016 | 02:11 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Well what code did it send? You may need the ECM tuned.
Old Aug 21, 2016 | 05:28 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
I agree, and it will make much more power.
Old Aug 21, 2016 | 10:34 PM
Engine: 305 Chevy
I've ordered a L69 ecu from another 1986 Camaro. Since the cam timing on the L69 engines are only 10 degrees less than the Comp 260H cams, I'm going to try that first. I'm going to the shop and readjust the valves to make sure all of the valves have been properly done. My pop thinks that may have been a problem.
Give me a couple of weeks on this one guys. I let you know what is going on.
