Compression test , bad engine ?
Old Aug 31, 2016 | 03:18 PM
kooga's Avatar
Car: Camaro IROC-Z 89
Engine: 28xxx miles
Transmission: TH700
Axle/Gears: 2.77 BW
How would an engine behave if the left bank showed 190-195 psi , and the right 175-180 ?
Would it make the engine feeling rough when accelerating ? Newly built engine (3500 miles) .
I did the test engine cold , and am about to tear it apart due to cracked head or bad headgasket , (airbubbles in the cooling system) .
Leakdown test didnt reveal any bubbles .
Old Aug 31, 2016 | 05:15 PM
Re: Compression test , bad engine ?
If it's that consistent, then more likely, you have 2 different head castings, with different chamber sizes. Check the casting numbers.
I doubt it would be noticeable while driving though.
johnny89345
May 30, 2009 09:51 PM
omcrider
Nov 21, 2003 10:58 AM
BOTTLEDZ28
Aug 1, 2003 02:13 PM
sancho
Dec 13, 2002 01:10 PM
sunbound
Sep 27, 2001 02:30 PM
