What does this wire go to?
Old Sep 4, 2016 | 08:45 AM
Cripley's Avatar
Hey guys this is my first ever 3rd gen and the wiring is a bit questionable to say the least. Items are cut, unplugged, crap added and then cut...so I will have many questions. I have attached a picture of a wire thats located near the AC system. Also, the second picture is located under the drivers side air duct, not sure what that hole is or is something should be on the hole. Thanks guys.
Old Sep 4, 2016 | 11:54 AM
Vader's Avatar
Re: What does this wire go to?
It would help to know what year and model, and the engine type. It appears to be a TBI without air conditioning.
The electrical connector could be intended for various things, including options that are not installed on the vehicle.
The opening over the exhaust manifold heat shroud is probably for the EFE preheat system. There should have been a foil/paper tube connecting that to a similar opening on the underside of the snorkel on a factor air cleaner housing. Replacements are about $3-4 in most chain parts stores.
Old Sep 4, 2016 | 01:27 PM
The green connector is the "test point" for measuring the mixture control solenoid dwell.
The other wire looks kinda like it might be for the O2 sensor.
Old Sep 4, 2016 | 02:45 PM
Cripley's Avatar
Its the 1984 z28 HO. L69. It has the ac, someone had told me it could just be a testing port. I thought that it must connect to the duct as it feels like that has a smooth piece of plastic under it that feels like it is covering a hole that that piece would go in. Thanks guys! I am sure I will have plenty of questions in the future and really appreciate the help!
djmarch
Exterior Parts for Sale
Aug 13, 2016 01:28 PM
dpmalibu
Apr 28, 2016 01:24 PM
soulreaper
Interior Parts Wanted
Mar 26, 2016 06:36 PM
gertie3993
Exterior Parts Wanted
Mar 18, 2016 12:08 AM
tecboy
Mar 16, 2016 09:52 AM
