Simple Fix?????????
Old Sep 7, 2016 | 11:25 AM
Javier87z28's Avatar
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
Simple Fix?????????
My 87Z28 305 tpi will not accelerate when pressing on gas pedal. The rpms slowly climb but upon releasing the gas pedal the car will accelerate forward? Anyone run into this issue??
Old Sep 7, 2016 | 12:43 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Re: Simple Fix?????????
My first suspicion is the TPS (throttle position sensor).
Old Sep 7, 2016 | 01:00 PM
Ill give it a check, I adjusted it a bit and it did idle quite better, thanks for your thoughts.
Old Sep 7, 2016 | 01:04 PM
thtanner's Avatar
I'd make sure you see voltage rise smoothly as you give it throttle. Should be .54 -> 4v+ if it's the same as mine.
Old Sep 7, 2016 | 01:18 PM
Ill give it a check tonight after work, thanks.
Old Sep 21, 2016 | 01:01 PM
So turned out not to be the tps sensor. Yesterday evening I unplugged the maf sensor and assemby and it idles high but keeps an idle and accelerates pretty smooth. Might this point to the Maf being the culprit even though its not throwing a code for maf?
BlueLightning
Mar 30, 2022 03:09 PM
Streetstuff
Dec 1, 2016 05:04 PM
9manastacio
87
Nov 22, 2016 08:26 PM
Thirdgen89GTA
Sep 7, 2016 06:42 PM
