4th gen rear end question??
Old Sep 10, 2016 | 11:08 PM
Lubricant's Avatar
I just finished swapping the rear end, it came off a 99 camaro z28 6 speed which apparently had 3.73s. Nothing to confirm though so I shall assume it has 3.42s like the stock one.
So I put the rear end in my 88 iroc nice brakes etc... sweet! But... I spin the yolk on the rear end and only one wheel is spinning... I thought all these rear ends had posi??
I haven't seen the car it come off of in person, but the dude had videos and all..
Is it gonna one leg doing donuts? Or is it gonna one leg doing a burn out?? Is the posi worn out?? I don't know...
Also I just purchased an adjustable panhard bar, will it fix my issue of the wheel sticking out more on one side?
Thanks..
Old Sep 11, 2016 | 07:52 AM
Re: 4th gen rear end question??
When you changed the fluid like any sensible person would when installing a used major part, and counted the gear teeth so that you knew for sure what gears it has, what carrier did you see?
Old Sep 11, 2016 | 01:08 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The one wheel spinning means it's either an open diff or a govlock. A govlock is not a posi but it will lock up both wheels when one starts to spin. The downside is the locking teeth are small and weak and they can break.
As mentioned above, pull the cover, change the fluid, count the teeth and examine the inside to see what's actually in it. There's always a possibility you bought an open diff.
Take pictures. It's easier to identify.
Old Sep 14, 2016 | 10:58 AM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Posi is bad or it's a v6 rear. Or both.
Old Sep 14, 2016 | 11:04 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I believe early 99 rear may have an auburn unit which is a clutch type posi. It could be shot and thats why its one wheel peel
Most 99-02's had a zexel torsen diff which is a worm gear posi. It wont one wheel peel unless its broke but you'd beable to tell
Early year 4th gens likely had auburns or something else i'm not sure
Or its a v6 rear
I agree with sofa, you should have checked the diff and swapped fluid out. That tell you what you got
Old Sep 20, 2016 | 03:33 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
IIRC, Auburn differentials were only used on late 4th gens, and ONLY on SS's and Firehawks as it was an SLP option, and NOT a factory GM option. They were fairly rare as well, but really not all that desirable as they really weren't any stronger than the anemic factory 10 bolts.
camarosource
Aug 16, 2016 07:20 PM
Pro
Aug 11, 2016 05:14 PM
ashmore27
Exterior Parts Wanted
Aug 8, 2016 10:10 PM
84Z28dude
Aug 6, 2016 07:08 PM
UK Speedbird
Brakes
Aug 4, 2016 10:02 AM
