Cold start issue
Old Sep 26, 2016 | 09:37 AM
jorgeblancojr's Avatar
Cold start issue
I just cold started my car and it started right up, but after it started it slowly turned off. It appeared that it couldn't catch a steady idle. After it turned off it just kept cranking until I applied the accelerator a little to turn it back on. Anyone know what it could be? Thanks.
Old Oct 5, 2016 | 11:11 AM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: Cold start issue
Some more info would be helpful...year/engine/fuel delivery system/modifications, etc.
Old Oct 5, 2016 | 02:07 PM
86 305 TPI stock.
Old Oct 12, 2016 | 10:37 AM
TPI ME's Avatar
Car: 87 Fiero with V8 TPI
Engine: 305 TPI from 87 GTA
Transmission: Getrag 5spd
Any check engine lights?
Old Oct 12, 2016 | 10:44 AM
No light or codes
Old Oct 12, 2016 | 07:44 PM
zed-028's Avatar
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
Check the simple stuff first
First stop is fuel - Check the filter, flow and pump/pumps, If its starting and then dies i would be thinking something to do with starvation
Next stop - I would go with vacuum leaks, the bane of any Thirdgen owners existence. So many to check, so little time...
Third stop - Spark, Plugs and Leads, Distributor cap etc. id call this one the least likely as it does start. However if youve got spark breaking down for any reason this could be the culprit. Look for screwed plugs, cracked leads and any cracks on the coil. check the inside of the distributor cap and rotor for burnout/wear.
Fourth stop - The exotic stuff EGR, Computers, Sensors, Etc. This is where the higher end pain in the **** troubleshooting comes in.
Enjoy
jorgeblancojr
Apr 4, 2017 01:20 AM
cougar20th
Oct 16, 2016 12:10 PM
merc64
Sep 28, 2016 05:56 PM
Gangsta Stude
Sep 26, 2016 12:23 PM
RABMAN
Sep 25, 2016 10:44 AM
