1991 z28 no start on gas only starter fluid
Old Sep 27, 2016 | 09:53 PM
ryan proctor's Avatar
I have tried several things and could not figure out why there was no pulse to the injectors put a meter on the 2 fuel injector fuse slots in the fuse block and there is no power to those two fuses, any help is much appreciated
Old Sep 29, 2016 | 10:25 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: 1991 z28 no start on gas only starter fluid
Are you checking them with the key on? Check the 20amp fuse next to the battery
Old Sep 29, 2016 | 12:14 PM
Yes sir, 20 amp is good by the battery, and key is forward.
Old Sep 29, 2016 | 09:32 PM
could the pickup coil in the dist be bad?
Old Sep 30, 2016 | 12:57 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
The ECM needs it for a reference signal to pulse the injectors, but the ECM is the ground side of the circuit. You should have power at the injectors with the key on.
Easy check for pickup coil is to pay attention to the tach during cranking. If it is completely still then the pickup coil is not sending a signal.
thewizard
Oct 18, 2016 12:23 PM
cougar20th
Oct 16, 2016 12:10 PM
Roblen91GTA
Oct 3, 2016 07:13 PM
Brinkkl2000
Oct 3, 2016 11:52 AM
Richard woody
Oct 2, 2016 11:57 AM
