A "click" when turning my newly installed shaft
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
I just replaced the steel driveshaft with an LSx aluminium shaft. Everything slipped in and bolted up fine (tight squeeze though).
But while underneath the car, transmission in neutral, i hear a click every half revolution of the driveshaft. I cant feel where its coming from but it sure sounds like its in the slip yoke area.
The click is also at a certain spot and not just random. For example, turn the shaft from 12 o’clock to 6 o’clock, click. Turn back to 3 o’clock, then to 6, click. Turn to 9 o'clock, then back to 6, click.
The rear Ujoint was replaced. The front is original but feels fine. There is no play in the shaft either.
(92 Z28, automatic, G80, 80k miles)
Car: 1992 Z28
Engine: 5.7 TPI
Re: A "click" when turning my newly installed shaft
Update: I put the steel DS back on, and I get the same symptoms.
So this is either complete coincidence that another issue pops up while i happen to be swapping out drive shafts. Or maybe this noise is normal until the rear tail housing fills back up with fluid? dunno
Hopefully 20ft/lbs toque is good enough for the yoke straps.
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Torque spec for the strap bolts is 12-20 ft.-lb.
I just tighten them until they strip and then back off a 1/4 turn.
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
whats the weight difference between the shafts?
Car: 1992 Z28
Engine: 5.7 TPI
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
I recall someone mentioning a cable/cable shield of some form under these cars that can slap on the tailshaft? anyone else recall this?
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
If it's making the noise every half rotation I'd say one of the joints is hitting something.
From memory, the Cat Converter heat shield is close to the drive shaft, but clear of the joint.
Maybe the hand brake cable?
Car: 1991 Z28 1LE
When ever I have the suspension hanging the driveshaft lightly bangs against the exhaust, but once the car is on the ground again there isn't any contact.
Car: 1992 Z28
Engine: 5.7 TPI
Thanks for replies. I checked again, felt around everywhere, and cant find anywhere around the DS that is tapping on anything. It seems like it may be inside the tailshaft or up further towards the front.
do you have rear drums on this thing? i had a funny click at one point that was a brake shoe stuck on and would click at every revolution. if youve got a drums, give them a few wacks with a sledge hammer, see if it releases.
Transmission: T700
Bad front universal joint?
Not expensive to replace both joints anyway.
Engine: 4++,350 & 305 CIs
It sounds like the governor weights in the rear area of the trans clicking. Which is normal.
Car: 1987 IROC-Z
yea, possibly inside the tailshaft is where your problem is. not hard at all to disassemble and investigate. might loose a little trans fluid but thats about it. might be a good time to replace the tailshaft o ring, rear seal and the bushing as well.
Car: 1992 Z28
Engine: 5.7 TPI
No they are discs. And the sound is defintely coming from up around the trans area.
