oil leak out rear of pan
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
i replaced the oil pan gasket cause it was leaking at higher rpm (spraying). I put a new gasket on and its still leaking right where the rear of pan meets the block. if I lay under car and person revs up I can see it coming out the rear gasket. can I pack some rtv around it or do I need a new pan?
Re: oil leak out rear of pan
I doubt that any amount of sealant will resolve the issue.
There's a considerable amount of crankcase pressure developed especially under high RPM conditions. A proper seal is needed to prevent leaks.
For what it's worth, and depending on the condition of the oil pan you have now, you might have luck with a new gasket and some RTV applied in the corners where the block meets the rear cap.
Are you using a one-piece gasket?
Is your PCV system operating as it should?
Engine: 355
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I would try one of the blue one piece felpro gaskets. Are you sure it is the oil pan not rear main?
Engine: 355
Engine: 355
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Could also be, the crack where the main bearing cap meets the block.
There's pressurized oil where the passage goes through the cap up into the block.
