what gears
Old Dec 28, 2001 | 10:06 PM
MCMLXI's Avatar
what gears
How can i tell what gears i have. Its a 91 z-28 350 TPI I recently had them replaced and they don't feel like im getting the same response out of them. It feels like i got less low end pull. I read on a post earlier that if you go 70 mph @2730 RPMs you had 2.7 3in the rear. I tried this and got 2730 rpms at 70.. HO w accurate is this?????
Please help i think i got screwed by the dealership
Old Dec 28, 2001 | 11:00 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
As long as you have stock tire heights and an accurate tach, this it works perfectly. Just make sure you're in D and not OD.
Old Dec 29, 2001 | 11:10 AM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
your certainly not going to be able to tell if they put in a different gear by checking your speed with the tach. no matter what gear you put in, the tach and speedo will read as if the stock gear were in there unless you've changed the speedo gear. if your questioning what they put in then take the part number off your reciept in and check with the parts dept to find out what gear it is.
Old Dec 29, 2001 | 02:11 PM
Car: 99 Formula
Axle/Gears: 342
True, the speedo will be off if the gears have been changed from factory and the speedo gear in the tranny wasn't changed, but the tach won't be affected.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
