Takingout cam, block out or in?
Old Dec 29, 2001 | 12:31 AM
BuddyLeeX's Avatar
Car: 06 Toyota Tundra SR5
When you replace camshafts, do u just take off all the pulleys and take out the radiator, or would u have to take the whole engine out and replace teh cam?
Old Dec 29, 2001 | 12:56 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Re: Takingout cam, block out or in?
You have to take off the intake and carb/TPI, distributor, pulleys, power steering, alternator, radiator. I even had to bend the front cross bars a little to get the cam all the way out. It is possible with the motor in. If your cars has more than 100k miles, it might be a good idea to go ahead and replace the timing chain as well. And don't forget new lifters, probably a good idea.
Old Dec 29, 2001 | 02:36 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Yep, just like Mark said.
I did mine 2 weeks ago and I helped a friend do his the next day.
Not really hard, just very time consuming.
Jake_92RS
Jan 28, 2020 10:37 PM
anesthes
Mar 10, 2016 10:35 PM
MoJoe
Sep 24, 2015 09:12 PM
gixxer92
Sep 1, 2015 04:32 PM
camaro71633
Sep 1, 2015 10:24 AM
