Where is the Manifold Air Temp sensor?
So I bought an 87 Camaro recently. It has a carbureted 305 in it if that helps. Anyway, I need it to pass deq before I can really start driving it everywhere but the check engine light is spitting out a code 23 which is a "manifold air temp sensor" as stated here:
http://www.iroczone.com/2009/10/1982...maro-firebird/
The problem is I don't know exactly where that is. It seems that quite a few things were changed or removed from the previous owners. There's no place on the intake filter (which I'm not sure is stock either) to replace any sensor and I can't find one on the intake manifold either. I can include pictures if that helps.
Transmission: 4L80E/4L80E
Re: Where is the Manifold Air Temp sensor?
Welcome aboard thirdgen.org.
Carbureted 3rd gens don't have a MAT. For them, Code 23 means mixture control solenoid or circuit.
You are my lord and savior. This makes so much more sense since I found the plug for that solenoid with nothing plugged in and I was wondering what it was for.
I'll settle for "helpful"...
Hope you can find the connector, and that takes care of the problem.
Now that I think about it, the location of the one plug seems a bit off for a mixture control solenoid. There's a plug in the passenger side fender and some other various plugs around the engine bay. Do you have any idea where the correct plug should be? Thanks.
Biochem
Apr 18, 2001 12:45 PM
