what do these items mean on my scanner?
Old Dec 29, 2001 | 09:41 PM
chrisfrerick's Avatar
what are o2 cross counts? reads 71
whats the differance between knock sensor and knock retard.
mine reads 213 knock retards. 0 degrees knock retard
idle air mtr position 86 steps?
Old Dec 30, 2001 | 10:32 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
O2 crosscounts are the number of time that the O2 sensor volatage has transitioned between rich and lean...450mvs, IIRC.
Looks like your scanner adds the total during the scan time.
Your knock sensor is the device that measures knock, located on the pass side of the block, knock retard is the amount of timing removed by the ESC.
213 knock retards? I'd guess this means that your scanner is displaying the total number of knock counts the ECM is receiving.
Idle Air Position is is where the IAC valve is at. The IAC controls idle speed.
F-body-fan
Jan 12, 2023 01:49 PM
Magman
Aug 2, 2016 08:32 PM
bigjay89gta
Oct 15, 2015 08:04 AM
okfoz
Oct 13, 2015 02:19 PM
e3pres
Sep 9, 2015 01:51 PM
