what should my base timing be set at with the following mods?
Old Dec 29, 2001 | 09:43 PM
chrisfrerick's Avatar
listed below.
Old Dec 30, 2001 | 07:23 AM
ede's Avatar
ede
not a real number but set it to where you get knock counts o nthe scanner then back it off a couple of degrees and recheck it. if it runs with out knock leave it there. if you're wanting to maxamize preformance you could do this along with making passes down a drag strip and setting the timing for best et, but a lot of other factors come into play, like traction. some people will say to set it using a vacumn gauge to reach the highest reading, but i'm not sure that is the best way to do it. most SBCs run good with 36* total advanve in them.
Old Dec 30, 2001 | 08:19 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Set the distributer to 6° and leave it there. You can't ajust total timing under the hood in a TPI car, you must do it in the prom(computer).
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Mutillator
Exterior Parts for Sale
Oct 1, 2015 06:05 PM
