1989 Iroc vert runs rough
Old Jan 14, 2017 | 02:01 PM
madigidy's Avatar
Car: 89 iroc z restoring
Engine: from 5.0 to 5.7
Transmission: from Auto to 5spd
Hey guys I have been wrecking my brain tring to fix this problem. I have a 1989 5.0 tpi auto. My problem is when i first got the car i had the normal items replaced plugs, wires, fuel pump, fuel filter. The car ran for a few weeks then it started to run so rough, to get the car home I had to pat the gas to keep it balanced from cutting off. Got it home and it sat for a couple weeks. I went to start it fired up fine ran for about 2 min and started to run ruff and cut out. I start again and have to feather the gas again and another couple min the idle return smooth. I did replace I believe it was the temp sensor on the intake manifold. Under the throttle body. I don't know what to do. I live in Maryland and we don't have any replicable shops here any suggestions.
Thanks for your help
Old Jan 14, 2017 | 02:17 PM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Re: 1989 Iroc vert runs rough
Are the original injectors still in there?
Old Jan 14, 2017 | 02:30 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
If they look like this,
swap to these.
https://www.southbayfuelinjectors.co...el-injectors-8
If you do replace the injectors replacing the fuel pressure regulator at the same time is a wise idea.
Old Jan 15, 2017 | 09:57 AM
madigidy's Avatar
I think so
Old Jan 15, 2017 | 04:08 PM
madigidy's Avatar
Hey again guys I went out probing around today while I have the injectors on order. So I noticed that a few rubber hoses have cracks in them. And I also noticed that the passenger side pcv valve lookalike it was never changed. But I could not pull it out because of this device can someone tell me what it and best way to get it off. I felt around it but only felt 1bolt. Thanks for your help again.
Old Jan 15, 2017 | 06:05 PM
Engine: Lb9
Transmission: M20
That's the diverted air valve. To remove it remove the two 10mm head bolts underneath it.
