Coil bad? Spark jumps to bracket!!!
Old Dec 30, 2001 | 09:35 AM
Little GTA's Avatar
My coil's spark is jumping to the bracket that holds it down. It is the remote coil for my 350 TPI. I noticed it has some white like material around it. I tried cleaning it...No change. I tried electrical tape over the bracket for some sort of insulation...No change. I tried a different coil to distributor wire...No change.
This evening I will try taking off each spark plug wire at the distributor to see if it is one particular wire that isn't getting the spark. Didn't try that before. Any other ideas?? Is my coil bad? It is the original stock coil (172K miles). If it does need replacing what is a recommendation? I would just want to replace the coil, nothing else...no MSD or ACCEL ignition, etc. Just the best replacement coil.
Old Dec 30, 2001 | 12:11 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
i'd say the best replacement coil is the hypertech for your car.
Old Dec 30, 2001 | 01:14 PM
Little GTA's Avatar
Spark plug not on the plug...
Problem more simple than I thought.
Genopsyde
Nov 11, 2015 10:46 PM
Bryan F
Aug 18, 2015 02:28 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
cstrobel65
Aug 15, 2015 10:19 AM
