Is a LT1 cam a direct swap???
Old Dec 30, 2001 | 11:45 AM
BowtieFever's Avatar
I am looking to have a LT1 Camshaft, rollers, and lifters installed in my LO3. Is it a direct swap? How much should I expect to pay a shop to do the swap?
Old Dec 30, 2001 | 12:31 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's almost direct... the only thing is, little dowel pin in the end of it is too long, it's long enough to go all the way through the timing gear and get to the Opti-Spark, and will rub on the timing cover of the older-style motors. It has to be knocked in somewhat to avoid this. Other than that, it's a bolt-in.
I have no idea how much you will have to pay somebody to swap a cam. It's probably a 8-10 man-hour job, at whatever shop rate, which is probably somewhere in the $50-60 range. Expect $400-450 of labor. Don't go with the low bidder; use somebosy that does this sort of thing (performance mods specifically) alot, like a speed shop, not Joe's Garage unless Joe is one of your local circle-track racers with a winning record.
1984HO
Mar 19, 2021 11:59 AM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
