crazy idle after door slamming
Old 02-12-2017, 08:44 AM
earls88's Avatar
Car: 1988 iroc z28
Engine: 305 tpi
Axle/Gears: 373
OK I replaced my TPS it's at 54 Volt's.
..In the am I can go out an start the car an it idles at 850-900rpms after putting it in gear about 780rpms.. Although after a drive I put the car back in park or neutral it likes to jump to around 1200 rpms ...I can cut it off for like 30 sec. An start her back up ..An it tries to idle at 800 ..I noticed the other day as my girlfriend closed the door the TAC jumped a couple hundred rmps an stayed there ..Then last night I slammed the driver doors an saw it jump so..I'm looking for new insight on this
Old 02-12-2017, 08:59 AM
Vader's Avatar
Re: crazy idle after door slamming
Connections, specifically at the ECM, are suspect. The block of orange wires (AUX/IGN power) are also worth looking into.
Old 02-12-2017, 01:39 PM
earls88's Avatar
Car: 1988 iroc z28
Engine: 305 tpi
Axle/Gears: 373
Kool thanks I'm going to poke around there ..I just cracked open the throttle with the adjustment screw an reset the TPS to 54 ..I'm not sure how to test for the constant 5v to the sensor thow if y'all have any insight
That be nice
