Camshaft Distributor Gear Question
Old Mar 23, 2017 | 10:02 AM
MadOTC's Avatar
Car: 92 Camaro RS Heritage Edition
Engine: 355 V8
I'm trying to finally get my car running again, and I can't seem to figure out what type of gear my cam has on it. I have an Engine Works 135286H, which is a hydraulic flat-tappet, but there seems to be limited information online about the Engine Works cams, and I haven't been able to confirm the gear type. It seems that the safe route would be to buy one of the composite gears for my distributor, but I would like to avoid spending that $100 if I can. Can anyone point me in the right direction on this? Thanks.
Old Mar 23, 2017 | 11:02 AM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Re: Camshaft Distributor Gear Question
Just the regular stock replacement gear is needed. You do not need a special hear for any flat tappet cam that I am aware of.
Old Mar 23, 2017 | 07:22 PM
zed-028's Avatar
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
aftermarket cams are made from a harder steel so getting a melonised gear would be advisable. If its the stock cam then the stock gear is fine.
Old Mar 29, 2017 | 06:06 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
That's not a billet cam. Use a stock gear.
