SEE HOW YOU SCORE
Old Apr 12, 2017 | 01:20 PM
gt4373's Avatar
Transmission: 5-Speed Manual
SEE HOW YOU SCORE
https://www.zoo.com/quiz/what-do-you...S-GnYN_KpCk48Q
Old Apr 12, 2017 | 04:01 PM
gordon24's Avatar
Car: 1987 Iroc-Z Camaro
Axle/Gears: 9 Bolt Borg Warner 3.45 Gears
Re: SEE HOW YOU SCORE
30/35
Old Apr 12, 2017 | 04:24 PM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
27/35
Old Apr 12, 2017 | 04:39 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
29/35 What the heck is a poppet valve and why do I care? Missed a few since I didn't read them right. One question was wrong. An OHV can also be an OHC in which case the cam is not above the crank in the block. In both cases the valves are over the head.
Old Apr 12, 2017 | 06:13 PM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
30/35. Had my usual gripes with these sorts of tests where some questions are written poorly or hardly relate. I've yet to see one of these tests that I feel is truly a good check of one's mechanical knowledge, but I guess it's OK for a quick time waster. At least it's not like one particularly devious grammar one where it gave you a false reading at the end. Reading the comments where everyone thought they did really well was quite entertaining after figuring that out
Old Apr 12, 2017 | 07:51 PM
Vader's Avatar
34, and I disagree with their "honing" philosophy. Obviously, whoever wrote the test never built a top fuel engine, and apparently doesn't speak American English as their primary language.
What the hell did they call a wrist pin? A "Gudgeon" pin? What the fark is that? Throw that in the back of your lorrie and **** off with it, mate...
Old Apr 12, 2017 | 07:56 PM
Drew's Avatar
It's written in Wheeler Dealer.
Old Apr 12, 2017 | 08:09 PM
LOL
Old Apr 12, 2017 | 08:12 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
31/35 eh?
Old Apr 13, 2017 | 04:35 AM
clubber's Avatar
Car: '92 RS
Engine: 5.0TBI
Transmission: TKX
32/35 and I missed the wankle question and I even own one. It doesn't have valves either so I'm saying it's 33.
Old Apr 13, 2017 | 05:11 AM
Croz's Avatar
agreed, I always thought it was called a rotary piston engine...stupid test..haha
Old Apr 13, 2017 | 06:25 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
34/35, click bait, can't believe I stuck with it!
Old Apr 13, 2017 | 10:08 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
35/35, but I had to use the hints a few times on some of the poorly worded questions.
Old Apr 14, 2017 | 01:47 PM
Vader's Avatar
There were hints? My script blocker must have prevented them from loading.
Old Apr 14, 2017 | 02:04 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
I got 17 for 17, then I quit. I'm lazy.
Old Apr 14, 2017 | 03:09 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Yeah, I didn't see any hints either, but then again I wasn't all that focused on perfection
