What is dwell variation?
Old May 2, 2017 | 11:27 PM
Nextgenx's Avatar
Want a title? Post!
Explain dwell variation
Old May 3, 2017 | 01:00 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Re: What is dwell variation?
"Dwell" variation goes back to breaker point ignition systems.
Dwell is a measure of how long the ignition points remain closed, in degrees of breaker point CAM rotation. Typically 29-33* on V8's. Dwell variation is dwell not holding consistent. Usually caused by worn distributor shaft and shaft bushings. It could also be caused by uneven wear on the breaker point cam.
Measuring dwell is done with a dwell meter, that was analog, back up to the 1970's. If the needle moves around, instead of remaining steady, you have dwell variation.
0pyders
Apr 30, 2017 08:02 PM
antman89iroc
Feb 9, 2017 08:48 AM
99Hawk120
Carburetors
Nov 20, 2007 02:38 PM
Momar
May 10, 2003 11:55 PM
IROCKZE
Carburetors
Sep 15, 2000 05:00 PM
