Car dies when put into gear. please help.
Old May 7, 2017 | 05:43 PM
Matthew1821's Avatar
Car: 1992 Camaro Z28 25th Anniversary
My car died suddenly while driving last night. I figured out that it was the ignition control module as I have replaced them before. But since I have replaced that and got the car running again, the car dies whenever its up to temperature. But only when its in drive/reverse. it'll idle just fine all day long in park or neutral. I took out the IAC and cleaned it but other than that i am pretty stuck.
Old May 7, 2017 | 05:52 PM
Re: Car dies when put into gear. please help.
my car is a 1992 z28 with the 350 tpi and 700r4
Old May 9, 2017 | 01:32 PM
anyone?
Old May 9, 2017 | 11:25 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
i had this exact problem years back, i was in complete denial that the iac needed to be replaced, even bench tested it and seemed ok. after so long dealing with it dying while putting it in gear i went ahead and replaced the iac valve and it never did it again, i attributed it to being and old iac that didn't have fast enough reaction time to adjust the idle for the gear change. there is a table in the ecm that has different iac positions for park/nuetral and gear position. i would just throw a new iac at it, they are fairly cheap.
Old May 10, 2017 | 06:32 AM
Not a bad idea to just go ahead and change it. i did pull it off and clean it, but it didnt seem to change the car any so ill just have to go ahead and change it. Ill let you know how it works.
Also i tested the 02 sensor and its saying that its stuck on dead lean but the car is running really rich so i think a bad 02 sensor could also be a problem.
Old May 10, 2017 | 08:47 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Do you have a check engine light or code?
Old May 10, 2017 | 10:05 AM
No lights, I check with the reader just to make sure and i just got the code 12. Which is that everything is running normal. but obviously its not.
Old May 11, 2017 | 09:59 AM
eaglesfan534's Avatar
Car: 1985 Pontiac Trans Am'
Engine: 305 LB9 V8
Axle/Gears: 3.23 9bolt BW
Let us know how it goes. I wonder if my IAC works on my 85'....haha
Old May 11, 2017 | 10:03 AM
midias's Avatar
Here are a couple threads on the same thing. Read them and see if anything you have not checked
Maybe try this one
If your transmission has overdrive, it sounds like the torque converter is locking up. Locate the blue square 4 pin electrical connector on the transmission, (this is for the overdrive) unplug it. Now start your car, put it into gear and see if it dies. If it doesnt die, thats your problem. You should be able to drive it to the shop like that, you just wont have overdrive. Hope this helps.....
https://www.thirdgen.org/forums/tran...fine-then.html
https://www.thirdgen.org/forums/tbi/...-when-put.html
https://www.thirdgen.org/forums/tech...es-when-i.html
