After 3 years in storage, Wont start
Old May 16, 2017 | 04:25 PM
OddJack's Avatar
Hello everyone, been away for long long time.
Just put a new battery in my 89 RS 5.0 and it wont start. 3-4 years in storage.
Looking for ideas and solutions.
Thanks,
Jack
Old May 16, 2017 | 06:45 PM
1986 iroc z28's Avatar
Car: 89 formula
Transmission: t5
Axle/Gears: open junk
Re: After 3 years in storage, Wont start
well, id start with the basics. Id hope you checked the vital fluids before turning it over, so the fisrt place to start would be spark fuel and air. Im guessing its still equipped with tbi injectioin, so the first thing to do is take the air cleaner apart and make sure no critters have nested in there. Then you can proceed to checking for fuel, turn the key to the on position and listen carefully for the fuel pump prime. If you can hear it prime, then move to the throttle body. take the air clean lid off and have someone turn the engine over while you look in the throttle body itself and look for the injectors. They should be spraying a noticeable amount of fuel while cranking. It they do, then move to spark. You can use a tool that goes in between the plug and wire itself to verify spark, or you can pull a spark plug wire off of one of the spark plugs, pull the plug out of the engine, stick it in the wire and let the spark plug rest on something metal to ground itself. Turn the engine over once more and watch the plug for a nice blue spark. If all of these thing are working correctly it should run.
Old May 16, 2017 | 06:57 PM
Vader's Avatar
Agreed. Keep it simple. Fuel, spark, compression.
While the plug is out check it for fuel fouling (soaking wet).
If the fuel wan no treated to a stabilizer the volatility may be about the same as kerosene, possibly even lower. If it gets down to a question of fresh fuel, you can manually administer some through the TB. If the plugs are not soaked/fouled with stale fuel, it should fire if there is spark.
Old May 17, 2017 | 07:40 AM
2012sergen11's Avatar
Car: 1987 Trans Am
If you aren't getting spark at the plugs I'd check/replace the ICM in the distributor. I drove my car into storage last fall and could not get it running last week, turned out no spark from a bad ICM that failed in a couple months of sitting.
Old May 17, 2017 | 07:56 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
"After 3 years in storage, Wont start"
Oh my.......really? Fuel Pump, Fuel, Spark, Air, Relays, Sensors, Water, Oil, Belts, Rust, Fluids,......
Check all that.
It would of been a miracle if it did fire up.
Old May 17, 2017 | 01:30 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
probably has stuck injectors-pretty easy to free up, see if car starts with a little gas poured down the TBIs
Old May 17, 2017 | 05:12 PM
OddJack's Avatar
Thank you everyone.
So, I went and listened for the pump and I could hear the buzz for about 1.5 sec.
That means except for changing the fuel I dont have anything to do with the back end? I was very worried about dropping the tank or cutting of a window on top to get to the pump.
Next I am going to open up the air cleaner and make sure it's clean. I have ordered a tool to drain the fuel and add some fresh gas. Right after that I will spray some gas in the TBI and see if it fires up.
Do you guys recommend adding some fresh oil to the engine?
Old May 18, 2017 | 11:25 PM
1986_IROC-Z's Avatar
Originally Posted by OddJack
Thank you everyone.
The buzz you hear is the pump priming. It means it's in some sort of operational state, but the true check would be to see what kind of pressure it's putting out, and if you're actually getting fuel up to the motor.
If you're going to drain the fuel, replace the fuel filter too. It's easy to do while you're under the car.
You should probably do an oil and filter change, but that has nothing to do with the starting issue UNLESS you haven't checked the oil and it's all leaked out. The engine will not start if the oil pressure is too low--it's smart like that (oil pressure cut-out switch tied in with the fuel pump).
Other than that, do your basic checks man. Look at all the fluids (brakes, power steering, oil, trans (auto) and coolant). Look over all the hoses and belts. Look for any loose electrical connections or wires. Pop the air cleaner to make sure it's not inhabited.
I'm assuming by "not starting" it will actually turn over, just not fire?
Old May 22, 2017 | 02:17 PM
OddJack's Avatar
Yes, it turns over..
SO I drained the fuel using a pump and put 2 gallons of fresh gas, then drained again and put another 2 gallons.
Now, the only way to get it to start for a second or two is to pour gas into the TBI.
I was thinking of finding the hose where the fuel is going into the TBI and pull it out and see if there is pressure? Any other ideas?
Old May 22, 2017 | 02:30 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Your injectors are probably varnished up not letting the fuel through. Take them out and clean/have them cleaned. TB right?
Chances are good that you have fuel all the way up to the TB.
Old May 22, 2017 | 04:21 PM
OddJack's Avatar
I ordered new injectors. After the cost of material and having it cleaned and adjusted the cost is close enough. I will follow up.
Old May 22, 2017 | 07:15 PM
OddJack's Avatar
How diffcult is it to change the injectors?
Old May 22, 2017 | 09:13 PM
rgauder's Avatar
Car: 1987 Trans Am
http://www.witchhunter.com/tbiremoval1.php
Old May 22, 2017 | 10:33 PM
OddJack's Avatar
Old May 26, 2017 | 01:45 PM
OddJack's Avatar
I took the injectors out. Waiting for the new ones to arrive.
Two questions
1-I cranked it up once to see any fuel in inside the tbi, didnt see anything, problem?
2- should I open up this part and clean it up? It seems to be spring loaded.
Old May 26, 2017 | 02:12 PM
rgauder's Avatar
Car: 1987 Trans Am
2. That's your fuel pressure regulator. If you got a throttle body rebuild kit, it should have a new diaphragm that you would use to reassemble the unit with. Taking it apart allows you to thoroughly clean the unit.
Old May 26, 2017 | 03:31 PM
OddJack's Avatar
is this the correct diaphragm? It has two extra holes
http://www.ebay.com/itm/Rochester-Th...1SDqwG&vxp=mtr
Old May 26, 2017 | 03:39 PM
rgauder's Avatar
Car: 1987 Trans Am
I believe thirdgens use a rochester 220 tbi unit.
Here's a kit with everything: http://marine-performance-parts.com/...ebuildkit.aspx
Old May 26, 2017 | 03:55 PM
OddJack's Avatar
thanks
does anyone know with injectors and regulator removed if I try to start fuel should show up inside the tbi or not?
Old May 26, 2017 | 07:13 PM
OddJack's Avatar
I am pretty sure fuel doesnt get to the tbi. It's dry, I put a new injector in there and still no signs of gas.
Fuel pump is working, so where is the problem?
Old May 27, 2017 | 12:51 PM
Vader's Avatar
Loosen the fuel line at the TBI to see if any fuel is flowing at all. If not the fuel filter is suspect. With a new filter, connect a test gauge and measure pressure. Expect 11-13 PSIG. Below 11 is not a good thing.
If no pressure is developed but you hear the pump running, you might have a problem at the pump assembly, possibly something like this:
If you are rebuilding the TBI injector pod, consider this:
http://www.wwdsltd.com/files/TBI-AFPR.pdf
Attached Thumbnails After 3 years in storage, Wont start-tbifuelpumppulsedamper.jpg
Old May 28, 2017 | 02:15 PM
OddJack's Avatar
Thanks Vader, I have ordered the adjustable regulator.
Old Jun 6, 2017 | 07:29 PM
OddJack's Avatar
I installed the new injectors and the adjustable regulator.
I opened the feed line, it's dry. No fuel when pump is priming.
ordered a new fuel filter.... but realistically, has a fuel filter ever failed by sitting for sometime? What are the chances? Has ever changing fuel filter solved any problems?
I just dread having to drop the tank..
Old Jun 10, 2017 | 07:35 PM
JA411's Avatar
Yes, but crack line into filter if fuel sprays when keyed up, it's propally the filter. Crack line after filter and check for fuel when keyed up. Remove filter and drain and blow thru, if restricted your ears will pop from the restriction. If blows thru easily it's propally fuel pump and or restricted pre pump filter.Test fuel pressure and volume. If tank comes down replace pump, pre filter (sock) and tank unit (if corroded or also have gauge issues). On F bodies I have done more fuel pumps than just a filter. I have done on brand new cars, when run low or out of fuel. Again test before any parts are replaced. Saves money and time.
Joe
Old Jun 16, 2017 | 11:25 PM
OddJack's Avatar
Yup Vader, that was the problem
