82 Z28 throwing codes 13 and 44
Old May 17, 2017 | 07:32 PM
millerliteliker's Avatar
I have an unmodified 1982 Camaro Z28 with the 305 carburetor engine. The car only has 3,100 miles. Pristine condition.
Obviously I had to deal with the normal stuff of getting a car to run properly that had been sitting up - rotten vacuum lines, change oil, flush radiator, clean fuel tank, etc.
The car starts up and runs great - no issues. Runs like a brand new car.
However, when it is fully warm and I stop at a traffic light, the "check engine" light comes on and then immediately goes off when I accelerate away when the light turns green.
I bought a ECM reader and got the codes 13 and 44 - left oxygen sensor. I changed out the sensor with a new one.
The light still comes on sporadically and goes out just as quickly. The car is still throwing those same codes (I did disconnect the battery to clear the ECM after I replaced the oxygen sensor).
Anyone have any ideas on what to check next?
Old May 17, 2017 | 07:38 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 82 Z28 throwing codes 13 and 44
The code 44 could be the issue. A lean condition would cause this to throw.other than the new o2 you just replaced . Lean Exhaust, check ECM wiring/connections, vacuum leak at the carburetor base gasket, vacuum hoses, & intake manifold gasket.
Old May 17, 2017 | 09:50 PM
OK thanks. Makes sense.
Old May 22, 2017 | 07:42 AM
Your advice was exactly right - I found alot of loose nuts / connections around the carburetor base and even the carburetor itself. Tightened everything up and the light does not come on anymore.
thanks!
Old May 27, 2017 | 03:37 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
If you changed the O2 sensor and still have the issue then you either have an actual lean condition caused by a vacuum leak or a bad ECM (computer) or the wire going from the O2 to the ECM is bad. I had to change the wire on my on 85 LG4.
It's a very simple circuit. Only three parts, O2 sensor, 1 Wire, ECM. Do have a multi meter?
Old May 28, 2017 | 05:16 PM
yes. circuit checked good. I ended up having numerous vacuum leaks around the carburetor and base. Tightened everything up and I have been good to go since then.
thanks to everyone's advice.
