1994 LT1
Old May 29, 2017 | 10:39 AM
pwachter's Avatar
Want a title? Post!
1994 LT1
will crane cam 104224 work in a 1994 Lt1 350 engine?
Old May 29, 2017 | 11:48 AM
Vader's Avatar
Re: 1994 LT1
Welcome Aboard!
It COULD work if the drive dowel pin is replaced with the longer one required by the LT1.
However, why would you install what is basically a stock Y-Body cam? If it's free, you would lose nothing other than the gaskets, fluids, and your time. However, a better choice for a basically stock LT1 might be the Comp 266HR-14, and even that is fairly mild but will require clearance checks for seals and coil bind.
Moreover, new springs and decent rockers will improve the installed performance of any cam installed, even the stock grind.
What kind of modifications are or will be done? Is this aluminum or iron-headed?
76Ventura
May 1, 2017 06:21 PM
hotrodf1
Apr 4, 2017 09:38 AM
88Greg
Mar 27, 2017 05:37 PM
Biggab12
Mar 21, 2017 04:48 PM
draven666
Mar 18, 2017 06:24 AM
