Edelbrock Performer 2101? Fit?
Old Jan 1, 2002 | 03:05 PM
BuddyLeeX's Avatar
Car: 06 Toyota Tundra SR5
Will this manifodl fit on my stock intake? Also I want to get an open element air cleaner, is 14x3 good and fit my q-jet?
Old Jan 1, 2002 | 03:42 PM
BuddyLeeX's Avatar
well also what I REALLY need to know is what series # of edelbrock performer intake manifold(s) will fit my engine since teh 7101 RPM performer wotn fit under the stock hood.
Old Jan 1, 2002 | 05:37 PM
BuddyLeeX's Avatar
ttt
Old Jan 1, 2002 | 05:53 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You really don't need a different intake. It's not the botleneck in your motor. The exhaust is the first thing you need to upgrade, all the way from the heads to the street, which you've done some of it seems. Then you need a cam. Then you need some heads, or at least some port work to the ones you've got. Unitl you get all of those things opened up, changing the intake will do very little to make the car run better.
Your gears are also costing you alot of performance. You wouldn't believe how different that car would be with 3.42s or 3.73s in back.
Avoid the temptation to spend your money bolting on stuff that looks sexy and visually gratifying. Attack the car where it's weakest, which is often in places you can't see. Save up your moeny and spend it on things that count, instead of wasting it on empty instant gratification.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
theshackle
Sep 17, 2020 08:26 AM
beastin91rs
Oct 9, 2015 07:38 AM
86IROC112
Aug 17, 2015 02:00 PM
TreDeClaw
Aug 14, 2015 06:58 PM
